Changing Spark Plugs
frl99
02-06-2004, 02:04 PM
If you read my other thread about my acceleration problems then this goes hand-n-hand with that. I went and bought some NGK plugs and I gapped them. I'm ready to change my plugs, I think. I have four seperate holes to where to where the spark plugs go in at (not sure what they are called). It's a 95 GS Eclipse if that helps. But how exactly do I change these spark plugs do I have to take anything ff the engine to get to them or do I just use a spark plug socket with an extension. Thanks
~David
[email protected]
Import2nr99
02-06-2004, 02:31 PM
just pull off the wires, and put the socket in with the extender. get it locked onto the plug, and give'er a twist. should come right out. be careful not to twist it to hard... if you break a plug off inside, you're screwed! once you get them all out, put the new ones back in. there is a grease that you can get to make them easier to pull out next time, also one for your wires to keep moisture out. they're like 60 cents, and will make the removal of your plugs and wires a million times easier next time. Good luck
1qwik4
02-06-2004, 03:27 PM
Change one plug at a time, this way you won't lose the order of which wire goes with which plug.
ashah000
02-06-2004, 04:00 PM
what did you gap them to???
kjewer1
02-08-2004, 06:13 AM
If youre the guy I made the suggestion to in the other thread, ignore my info. I dont think I realized you had an NT. If you are not that guy, ignore this post too :)
