Head??
KoRnSaQ
02-05-2004, 07:56 AM
OK, I have to change out my head gasket this weekend, and i was wondering what is the quickest/easiest way to pull off the head to do this. please get back to me ASAP
marked001
02-05-2004, 08:02 AM
..the typical normal way..haha..there's really only one way to do it ;)
KoRnSaQ
02-05-2004, 08:05 AM
ya, i know, but will i need to take the intake crap off or would be able to just leave it on and take it off with the head??
kris
Jack car up, put car on jackstands, slide under car with 12mm rachet, undo bottom two bolts on the intake manifold bracket (unless it was previously removed), slide out from car, undo all hoses, lines etc going into manifold, take off dizzy, unbolt exhaust manifold, take off valve cover, take off timing belt cover, zip tie timing belt to cam gear AND mark the t belt on the cam gear, undo cam gear bolt, take cam gear off, undo all 12mm head bolts, grab back of IM and EM studs, and lift.
Just so you know, the 4th gen head gaskets are a lead type material, so it will be a PITA to get all the material off. You might wnt to look into getting it milled.
KoRnSaQ
02-05-2004, 08:10 AM
Ok, thanks Kris that will help me out a lot.
