probe E brake
thunderbird muscle
02-04-2004, 05:56 PM
how do you take of the E Brake cover of a ford probe a member in our cargroup Wicked Innovatons has a problem with this peice.
Fizer70
02-04-2004, 09:49 PM
Are you talking about just the e-brake or the whole armrest and center console?
Basically, the top cover comes off easily. There is a recessed area on the driver's side that you can pry up on. After that remove the screw that is located on the driver's side of the e-brake cover. As you can probably see, there are plastic clips on the inside...just separate it and you are done.
SirRage6969
02-05-2004, 12:00 AM
i did an e brake cable in my 90 and it only took like 30 minutes on the lift with air tools
