Can someone help my Honda
Skigin92
02-02-2004, 01:16 AM
Every time i start my car it shuts back off i keep trying and after a while it will start but it is taking longer each time.Can any help :banghead :banghead:
4GZChatch
02-02-2004, 08:33 AM
Sounds like a fuel issue to me, have you changed your fuel filter lately? I'd start there and new plugs/wire/cap/rotor to make sure you're getting good spark and fuel delivery...
Killa_CRX
02-02-2004, 10:08 AM
Sounds like a problem I had with my ignition switch once (the switch behind where you stick the key in to start).
I could turn it to the 'start' position and the engine would crank and turn over, but when I let the key back in the 'run' position the car would shut off.
The ignition switch was worn out on the 'run' position.... replaced the whole switch with a new one, and never had that problem again.... It's a very quick and easy fix.
Easy way to tell if that's your problem, without buying a new switch.. take the switch out of the steering column and look at it for an bad looking burn marks on the connections... if you see any, that's probably your problem.
