won't start....just clicks
Jazbar
01-29-2004, 12:50 PM
Hi everyone,
I had no problem with my car (97 Grand Prix GTP) the first two times I used it today. Everything was fine accept for the slightest of things.
While in park I noticed the tack drop from 1000 to 500, I gave it alittle gas and all seemed fine. Got home shut it off.....still fine. Couple hours later I tried to start it and it won't turn over.....I just get a repeating click coming from the engine compartment when I turn the key.
The interior lights seem a little dim after trying to start it a few times.
I put the battery on the charger for a couple hours but that didn't help.
Is the clicking normal for a bad battery? Or is my problem more likely the starter?
Thx
Thx
Jazbar
01-29-2004, 01:16 PM
Just used another charger with an indicator light for "fully charged" and the light kicked on about thirty seconds after I turned it on.
So......I guess its not the battery.
Any input would be appreciated guys.
Thx
Thx
jcas1411
01-29-2004, 01:43 PM
My best guess is it sounds like the starter cylinoid has went out. This is probably unrelated to the RPM flux. You can take the entire starter out and test it at your local autozone. Pretty easy task to take out.
Hope this helps.
Hope this helps.
carnutcass
01-29-2004, 02:01 PM
I place my vote for bad battery. How old is it?
vette84
01-29-2004, 02:30 PM
sounds like bad battery or maybe bad altonator??? if it was starter cylinoid it would be free flying not clicking.
JJUBECK
01-29-2004, 02:41 PM
Check your battery connections too, if there crusted and nasty looking you could have a power loss there.
Jazbar
01-29-2004, 03:29 PM
Battery is a 2 or three years old. Connections are clean and tight.
If it was the battery wouldn't it turn over slowly at least.....cuz there is at least some charge in the battery.
Altonator was replaced about three years ago.....christ, I hope
that ain't dead again.
So if it was the starter cylinoid it wouldn't be clicking......
so either the alt or the battery?
Thx for your responses guys.
JJUBECK
01-29-2004, 03:35 PM
Okay you can check the starter before you take it off, just take a hammer and have someone try to start the car while you LIGHTLY tap on the starter. Ghetto I know but hey its worked for me many times over. Also you might want to check the connections at the starter, if you have a loose wire there the samething will happen.
vette84
01-29-2004, 05:20 PM
my sister grand am did the same thing but it was the battery,it gets so dead it dosen't have enogh to turn over so it clicks!!!!! THATS ONE OF THE FIRST THING THEY TOUGHT ME IN AUTO ENGINENARING!!!!
jon@af
01-29-2004, 06:06 PM
Most likely it is the battery, as everyone else has said. I see it all the time at work on cars that havent been started in ages(on the used car lot).
JOEROC
01-29-2004, 06:43 PM
First i would do a voltage test on the battery, has to be 12 volts or a little over, use an ohms meter set at DC volts.
Second, is your starter clicking or the starter relay clicking ?
if its the relay more then likely its your starter thats bad. there are springs in the starter selinoid that get brittle and break.
Third if you do get it running do a voltage test on the alternator
should be about 13.7 volts or better.
Hope this might help.
gtgp97
01-30-2004, 01:18 PM
My vote goes towards the battery also. I have not had a car do this but a jetski and motorcycle click when the battery was low on power. Borrow a battery from another car if you have one and see if this solves the problem.
94gpse
01-30-2004, 04:35 PM
You can check the battery first. But I had this problem before, so I checked the battery, cleaned the terminals real good etc... and it still wouldn't start it just clicked. The problem ended up being the starter. So I think it is your starter. Hope this helps.
JJUBECK
01-30-2004, 06:15 PM
Yes it sounds exactly like the battery is died, however if your testing the battery and its coming up ok then I would start either checking the starter or maybe a lose connection or a short in the wire somewhere.
Jazbar
02-01-2004, 10:42 AM
Thanx everyone for your input. All who guessed the battery were correct. Runs like new now.
Again......thanx for all the help guys!
carnutcass
02-02-2004, 09:21 AM
Not a bad idea to go ahead and get the alternator checked. AutoStoned will do it for free. A poorly performing alternator can contribute to the early demise of a battery.
kilroypr
02-02-2004, 03:39 PM
I couldn't agree more to that. When the battery last less than 30 months under normal driving conditions the charging system might be at fault
kuriousg123
02-20-2004, 01:52 PM
Hi everyone,
Thx
I have a couple solutions to your clicky problem. You see,... I've had that problem a few times
- It's probably a combination of your alternator and your battery wich is going to run you just under $1000.00 CAN.
- Or... if your lucky... check your fuse box in the glove compartmet. Top right one down... a little yellow fuse should be there... if it's not there you have found your problem.
You see, you get the click when you turn th ignition because there is no power getting to the starter. This is definely a powere problem. GOOD LUCK!!
Thx
carnutcass
02-20-2004, 04:32 PM
I'm not flaming you but.......$1000 for a starter and battery??
