Delco radio loc?
gcaste
01-27-2004, 11:46 AM
I work for GM and think this radio loc is a bad idea. Anyone who buys a used car is out of luck.
I retrieved my six digit code from the radio but how can I get the unlock code when I call the 800 number if I don't have a dealer code?
Help if you can save me $30.
Sammysurfer
06-26-2004, 02:33 AM
How did you get the Six Diget Code I Tried mine in my 2000 And it does nothing? I Got a dealer code but Ill have to dig it up Forgot where i put it
pitbull2827
01-03-2005, 09:58 PM
This is the process for the CD deck. I assume it's the same for any 88-90 deck with the DelcoLok system. It may also work with 90+ DelcoLok I units.
1. Press and hold presets 2 and 3 for about 5 to 10 seconds until you
get 3 digits on your display. This is the first 3 of 6 digits you will
need, so write 'em down. (mine were 881)
2. After doing step one and writing down the code, immediately press the
AM/FM button to get the last 3 of the 6 numbers you'll need, and write
'em down. (if you wait too long between steps 1 and 2 and the LOC code
displays again, just start over). (mine were 322)
3. Call this number, it's a prerecorded message, so don't worry about
having to talk to anyone...1-800-537-5140. The voice will ask if you're
calling for Chevy, Pontiac, Cadillac, etc... When you hear this,
press 1 for chevy, followed by 02107and hit the * key. (i.e. 102107*) He'll ask you for the 6 digit code that you've written down.(mine was 881 322) Enter that and press the * key. He will then give you a code,(mine was 810 891)
4. To unlock the radio:
A. Turn the ignition on.
B. Press “SET” (000 appears on display).
C. Press “SEEK until the first digit of the code appears.
D. Press “TUNE" until the second and third digits
E. Press "AM-FM" (000 appears on display).
F. Press “SEEK” until the fourth digit of the code appears.
G. Press “TUNE” until the fifth and sixth digits of the code appear.
H. Press "AM-FM". Now the radio can be turned on.
see that help you good luck!!!!
shompy
01-24-2005, 10:22 AM
Hi Friends, I'm new in this site and i want to expuse my case.
I've a GEO Tracker 95 with a Delco Radio (MOD 30010113), and offcourse it's locked.
I followed the steps to get the numbers and call, but I just can get the first set of them, this is, I push the 2 and 3 presets buttons and writed the numbers from the display (5632) and inmediatly push the AM/PM boton, but nothing happened. I don´t know if this radio model need the other numbers or it's something wrong with it.
I tried to call and make a test with just this numbers, but something is not working (maybe because is a international call, I live in Costa Rica).
So, I'll appreciate any help...
Thanks a lot...
Thanks a lot...
