Will a dizzy from a a6 work?
Hybrid1990crx
01-22-2004, 11:22 AM
Will a dizzy from an d16a6 work on the d15b in my hf?
Killa_CRX
01-22-2004, 11:31 AM
If you have the A6 ECU as well.
marked001
01-22-2004, 11:45 AM
..from what I've been reading online.. it seems that the only real difference between the hf and the si distributor is that the hf dizzy may have a weaker coil.... so sounds like it should work :)
amy@af
01-22-2004, 11:50 AM
that was my thoughts. but i have never owned a hf so i wasn't 100% if the 90-91 did have a pm6. we have owned a 90-91 hf engine. noticed the intake mani looked the same but ports appeared smaller. anyone else notice that?
.....waiting for 91civicDXdude to reply. he'll set us all straight :grinno:
lilol89crx
01-22-2004, 02:26 PM
as far as hf and si dizzy compatability they both work the same. both are set up for mpfi(internal sensor) if you take a look into both dizzy's, the reluctors are both stamped pm6. the a6 dizzy will work with either the pm8 or the pm6. as far as the coil goes im not so sure.
