AIR DRIED BEEF DOG FOOD
U.S Wheels with Super Swamper Radial TSL
akordboy
01-21-2004, 12:40 PM
I am thinging about getting this wheel/tire package that consists of the Rock Crawler wheels (made by U.S. Wheels) with the Super Swamper Radial TSL's. The size tire I wanna get is 285/85/16 mounted on 16x8" wheels. Will there be any problem with this or should I go to a 15x8" wheel. The tire also comes in a 265/80/16 size. Thanks.
:2cents:
Jeff
OffroadX
01-21-2004, 03:59 PM
285/85-16 would be 35x11.50. That won't fit without A LOT of work, which wheel is the least of your worries. Also, a 15x8 won't make a difference, you can't mount a 16" tire on a 15" wheel. Hello???
265/80-16 is a 33x10.50, do-able, but only if the backspacing/offset is perfect, otherwise you'll need a body lift and it still won't quite be right.
Brent
akordboy
01-22-2004, 12:24 PM
Brent
Thanks Brent for responding, However I am not an idiot. I do know that you can't mount a 16" tire on a 15" wheel. I think that I am going to go with the 32x11.5 BFG K/O AT's on the 16" wheel. I do alot highway traveling, so they are the best bet. Seems after doing research on the U.S. Wheels, they seem pretty good.
:sunglasse
Jeff
