ur problem
mike_and_deidra
01-20-2004, 12:16 AM
I had that problem with mine also and i think you might have the same problem i did. On the driver side fuse box inside the door their is a fuse towards the bottom(like third one up to the left) i think, anyways, if its shot the car will crank and die, thats what mine did, so i changed out the fuse and it solved the problem. check it out, might be sumthin as simple as that
