tchic
97tbirdman
01-16-2004, 01:23 PM
i have a 97 tbird and i believe a have a short in the turn signal but im not sure where. the right flasher works fine when the turn is not all the way up, but when it gets latched into place it blinks rapidly. the bulb has already been replaced and i have checked the fuse. im not completely sure where the flasher unit is. also my hazards dont work either. fuse for that is fine too. can anyone help me figure out whats wrong?
also was wondering how much stock hp the 4.6 has in the 97 tbird and what kind of mods would be best to help boost that.
turbocoupe
01-16-2004, 03:51 PM
have the flasher replaced
8ate8
01-16-2004, 11:19 PM
It's a bad multi-function switch. Occasionally the same thing will happen to me. Also my high beam flashers don't work.
Many people run into problems with the multi-function switch. If you replace it, all problems should be fixed.
RavenProjecT
01-21-2004, 08:49 PM
the 1997 4.6L engine was rated at 205 HP.
see your other post for info on how to increase HP.
