Noise
Razor19
01-12-2004, 09:43 PM
I have a 96 Mustang GT, its drive perfectly fine, but I hear this small little noise that sounds like its coming from the back of my car like maybe from the exhaust. It almost sounds like a chirping noise. I was sitting in my car trying to figure out what was causing the noise I noticed that when my car was idling when I let up on the clutch the noise would start again but then when I pressed the clutch down the noise would stop and it would do this everytime. Anybody got any idea what could be causing the noise and how to fix it?
HiFlow5 0
01-13-2004, 06:39 AM
Wow, check engine lights and rattles. Sounds like you got all the problems. LOL
MustangRoadRacer
01-13-2004, 09:14 AM
sounds like a valvetrain issue.
MustangRoadRacer
01-13-2004, 09:15 AM
edit - Drivetrain.
DDMTK421DS
01-13-2004, 01:18 PM
If you get "chirping/and or clicking-clacking noises and you can stop it by pushing in on the clutch a bit ............:smokin:
It is most likely your Clutch throwout bearing:banghead:.....If you "upgraded" your clutch, you must install a "firewall clutch kit" to tighten the cable just right so it is unable to make the noise...
I have/had the same noise and am having a Firewall kit installed to reduce the noise........:eek7:
Also, If this IS the problem, (I drove my 98gt a year with this problem), it won't hurt your car at all.....it is just annoying! lol :rolleyes:
