'95 Camaro Z-28 Wont Crank
emtabmm
01-12-2004, 10:11 AM
Hi, I have a 1995 Z-28 that will not crank to start, no dash warning lamps come on or anything... Any ideas???? Battery is up, radio works, blower works, just no crank and lots of clicking under hood, have replaced battery....
Vlad_Tepes
01-12-2004, 10:21 AM
Sounding like a bad starter... Check the wiring might just be loose... If its not that then take off the starter take it to AutoZone have them test it
emtabmm
01-12-2004, 10:29 AM
If I run power straight to the starter it cranks ok but wont start.
Vlad_Tepes
01-12-2004, 10:34 AM
got a problem in the wiring somewhere or maybe the fuse link
89IROC&RS
01-12-2004, 07:53 PM
definately a problem with a connection somewhere between the ignition switch and the starter solenoid. make suer when you put power to the starter, that your putting it to teh solenoid, and not the motor its self. sometimes the wiring goes bad between them, and the motor will work fine when hard wired but wont get the signal from the solenoid which is controled by the ignition switch.
emtabmm
01-13-2004, 12:39 PM
Thanks for the replies, found the connectors at the ignition switch melted down, had to replace both connectors, repair the wires.....
badazz383camaro
03-23-2004, 11:40 PM
Hey have you checked the crankshaft position sensor yet? It might me the problem. That was the problem with mine.
