mpfi conversion
EFhatch91
01-11-2004, 04:50 PM
i completed the wiring for the mpfi conversion but car will not start. the starter is not making any noise.
please help
please help
jacer
01-11-2004, 04:54 PM
Is The Starter Wire Plugged In?? Motor Have A Good Ground?? Fuses??
EFhatch91
01-11-2004, 04:56 PM
starter is plugged in, but the ground that goes to the valve cover is not on the bolt that it was originally becuase one of my friends snapped it
jacer
01-11-2004, 04:59 PM
That Should Not Be A Problem As Long Its Grounded. So You Get In And Turn Key And Nothing??no Start?? What Exactly Did You Swap Out??
EFhatch91
01-11-2004, 05:10 PM
i am using a 90 civic si ecu, manifold, resistor box, and distributor.at first i tried the conversion using the stock si engine harness which i later found out does not work, so i went to the junkyard and got another stock harness and completed the wiring and everything. when i turn the key the fuel pump goes and it just doesnt crank, i am going to try to use a friends crx starter tomorrow.
EFhatch91
01-11-2004, 05:15 PM
the clip that is on the block by the oil pump where there is 2 wires, does it matter which one goes to which?
jacer
01-11-2004, 05:18 PM
I Dont Think So U Mean By The Oil Filter??
EFhatch91
01-11-2004, 07:41 PM
yeah
spongerlbc
01-11-2004, 08:20 PM
There should be 3 wires hooked up to the starter, one is kinda annoying to get on. Also, check your ground on the thermostat cover.
