installing ecu
crx hf
01-08-2004, 08:02 PM
Well i just got my si ecu.I know u have to take off the 4 bolts to take the shield off but i dont want to mess up my car by just yanking the ecu from the harness.So my ? is how do u install it.
91civicDXdude
01-08-2004, 08:22 PM
1. pull back passenger floor board carpet.
2. remove the 4 10mm nuts from the ECU shield
3. pull the ECU up off it is 4 mounting studs
4. unplug the three plugs on the left side of the ECU, there will be push tabs in the center of the three plugs
5. installation is the reverse of removal
enjoy.
enjoy.
jacer
01-08-2004, 08:24 PM
well after you take shield off thers 3 plugs that plug in the ecu. unplug the three and plug in your new ecu that easy!!!
crx hf
01-08-2004, 08:37 PM
Thanks guys :smokin:
jacer
01-08-2004, 08:42 PM
your welcome! quick question? where did you get the si ecu?? i got mine on ebay for 35.00
FourthGenHatch
01-08-2004, 09:02 PM
Junkyard is the best place to get an ECU. I got my PG7 at my local yard for $25. They are only ebay for 4x that sometimes.
