SI head on STD engine
blade34609
01-07-2004, 04:33 PM
Hi,
I am replacing my headgasket in the STD hatch this weekend.
Anyways, I have a spare SI engine with the header still on it.
While im replacing the head gasket i decidied to also in put the SI header on, instead of the restrictive STD header.
However, I do have the complete head from the Si engine.
Is there any advantage to put an SI head? More compression?
Will I gain any hp worth doing?
Also, should I replace the valve cover gasket while Im at it?
Thanks
Thanks
91civicDXdude
01-07-2004, 07:11 PM
bigger lift cam. i'd do it if i were you
