A ford
techn9ne
01-07-2004, 09:33 AM
can u tell me step by step how to change a drive belt on a 96 ford probe 4 cylinder!!!!!!!!!!!
techn9ne
01-07-2004, 09:40 AM
please help!!!!!!!!!!!!!!!!!!!!
The Bondo Bandit
01-18-2004, 08:51 AM
it should have a tensioner , look for a little wheel with nothing mechanical looking behind it . generally that pully is sprong loaded , put a ratchet on the bolt in the middle and push to the right , it'll pivot down and you pull the belt off . it's pretty easy . don't quote me on that though , never worked on one of those , done it on a bunch of other cars though and thats how it went . and theres normally a picture under the hood of how the belt goes , but it wouldn't hurt to draw it out incase there is not diagram .
Overtime
01-20-2004, 07:35 PM
Here is how to find the tension release bolt on my 95. Find the power steering pump. Just under the pump is a tention release bolt. I missed it the first time I had to do work on my car. If I remember correctly, you have to "tighten" the bolt which will allow the pump to relax the tension on the belt.
