Integra Parts For Cr-v Help!!!
sawsawsarap
01-06-2004, 09:35 PM
Someone Said I Can Use Some Of Integra Parts For My 1gen Cr-v. Could Anyone Specify Which Parts Exactly Will Fit In My Car. Been Looking For A Set Of Headers. Thanks!!!
whtteg
01-07-2004, 04:22 PM
Well the header will bolt to the engine but I am not sure about how well it will line up with the exhaust. But to answer your question as best I can the B20 and the B18B1 are basically the same motor , the B20 just has a larger bore. But you can swap any part of the motor to the B20, it will fit the motor but you might have problems with other stuff in the engine bay.
HondaIntegraXSI
01-07-2004, 05:28 PM
for the 1st g I would put a pair of LS camshafts and ECU in it. Ayso the CRV is a Civic chasse so theretically (I can't spell worth a shit) the civic Exaust will fit the CRV. You may ayso want to do a v-tec head swap, but I don't personally approve of it. Instead you may do a complete LS head swap because the valve ports are 1mm biger than the B20B and .998mm bigger than the B20Z.
whtteg
01-07-2004, 09:39 PM
I have a LS head if you are interested :p
sawsawsarap
01-07-2004, 09:42 PM
thanks guys! hey how 'bout a set of b16 headers? is that same as the ls ones? someone slapped in one on his crv. just wanna make sure its ok before i actually purchase any parts.
HondaIntegraXSI
01-08-2004, 05:45 PM
yea, it will bolt up to your motor, but they might not bolt up to your exaust. If I were you I would get the B16A header, a straight cat, and a custom exaust welded on at like midas or something. Just and Idea
