92 Rodeo hydraulic clutch problem
bfr57
12-31-2003, 09:52 PM
Drained the fluid from the clutch before replacing the actual clutch. Got it all back together and can't get the clutch pedal to pump up. I've got good fluid out of the bleeder, but no pressure, the pedal goes to the floor and stays there. Any ideas?
cheekatall
01-21-2004, 11:57 AM
replaced mine (clucth master cyl.) about 2 month ago and had the same problem. replaced with a remanf 2x. then replaced it a 3x with a wagner, exact same one as original, only one I could get to return the pedal. You got to build the pressure up when bleeding and I final got the pedal to return. I beat myself up doing it. It will take some serious pedal pumping. at first I had to use my arms to pump the pedal. one other problem I had is that when you pump real fast blubbles in line get real small. It took me two different go arounds to final rid the system of all air, good Luck, you are on the right track. almost went thru a large bottle of brake fluid.......
