Fog Lamps do not work
JonJon68
12-29-2003, 08:23 AM
Hi, please, any suggestions would be of help. I own a 97 Pontiac Grand Prix GT 3800 and the fog lamps do not work. I've checked the relay and fuse and they are working because I switched the same size relay around to check. I'm assuming it has to be a electrical problem because the foglamp switch inside the vehicle doesn't show a glow when it's turned on. Furthermore, I checked the bulbs and they are fine. Thanks for any help..... I bought this car on e-bay and this is the only part of the car I didn't ask about before the deal was finalized. Everything else works and I'm very happy with the car.
kilroypr
12-29-2003, 11:52 AM
If the fuses and relays are ok then the switch went south. REplace it
Ripn12s
12-29-2003, 05:06 PM
First make sure the switch is pluged in. Real easy and doesnt cost $$
When I had my stereo installed the shop forgot to plug the switch back in, I checked everything that you just mentioned and nothing. Someone told me to check the switch and said it wasnt plugged in and sure enough.
JonJon68
12-29-2003, 06:27 PM
ough.
Thanks a million. You hit the nail squarely on da head! Got in there and sure enough, it wasn't plugged in......:- ). Works fine now.
ough.
michelle.1983
03-09-2004, 11:26 PM
My fog lights are not working either, I need to know where do I check to see if the switch is plugged in?
gtgp97
03-09-2004, 11:35 PM
i havent tried this but maybe open the door and pop out the panel on the side of the dash with a flat tip and take a look up there or feel around...
Ripn12s
03-10-2004, 07:15 AM
Just pull the dash panel back and check to see if the switch is plug'd in. Also check the fuse and relays in the engine bay.
