alternator install help (1994 camaro z28/1995 trans am)
taylor2527
12-26-2003, 06:17 PM
hey guys, i am insatlling a new alternator in my 1994 camaro z28 with the 350 lt1 engine. i was wondering how you take the belt off using the spring loaded system. could someone plese give me some information on thi subject. i was wondering about which is the easiest way to install a new alternator and if anyone has any tips or suggestions it would be greatly appreciated. thanks
1Formula
12-27-2003, 07:47 PM
To remove the serpentine belt is very easy. Get the car up on stands or ramps. Get a socket and wrench and put it on the spring loaded 'pulley' and i believe you pull down to release tension on the belt....slip the belt off while the tension is released and whalla! The belt is off! Easy. It's easier to put it back on with 2 people. One person holds it in place and the other releases tension. The alternator is easy to replace also. 3 bolts i believe watch out for the big terminal and the connector on the back. Remove your negative terminal from the battery before you remove the alternator....that big terminal in the bag of the alt. is positive+ from the battery so you don't want it to ground out.
