Lights on Dashboard
blknyt07
12-23-2003, 03:25 PM
I have a 97 GT 2 door. Does anybody know what to do about the ABS light and the check tire pressure light being on all the time?
JJUBECK
12-23-2003, 04:35 PM
Have you checked your tire pressure and brake fluid levels yet? It also might be trying to shoot a code out, you might want to take it to autozone to get a diagnostic.
rockford0384
12-25-2003, 07:47 PM
Dude you have a wheel bearing going bad, soon it will be humming. My brother had a 97 gt and I have a 97 GTP and we both have had the same problem trust me.... Its that... just wait it out until you get a humm. then find out which side its coming from (drivers/pass) It will be mostlikely be the front! so listen. Or if you dont want to, put the front end of your car up on jacks and play with the wheel pull and push from the top and the bottom of the wheel is it has play in it That wheel will mostlikly be your problem. Mine went out in california. (I live in michigan-fyi)questions just ask! I wont be around for a week starting the 26th so. Email me ill be glad to help
Ohh NAPA charged me 186 dollars for one... but it came with a lifetime warranty-fyi just so you know what your looking at. And there not hard to replace
kilroypr
12-25-2003, 11:45 PM
Check the codes. Get your car to a shop and have it scanned. It is very possible that the bearings are the problem but it might be something else.
kilroypr
12-25-2003, 11:47 PM
Just to make sure you nail it down
blknyt07
01-02-2004, 09:05 AM
I did have the wheel bearing replaced on the front left and the front right should still be in good condition. However, i wonder if the wiring is bad in the bearing. Could it be possible that the sensor is not pointing where it should be? I heard that if it's somewhat off it's track then it would trigger those sensors. I do feel it's in that new wheel hub and I do have a lifetime warranty on that baby. Let me know if anybody thinks there might be something else going on.
