"Tak Tak Tak Tak" sound on morning start
botaking123
12-22-2003, 11:21 AM
Hi,
I have this Hyundai GETZ 1.6 DOHC car. Recently I have this weird Tak Tak Tak Tak sound on morning start. The sound only lasting for 2 or 3 mins only. I'm not sure from where this weird sound came from. Checked & adjust all the belts tension with my mechanic. But the sound still happen on cold start. Please advise me on this matter.
mechy1barry
12-22-2003, 02:22 PM
sounds like a lazy lifter,have your mech with you when you start from cold and have him listen under the bonnet at top end of motor.
mechy1barry
12-22-2003, 02:26 PM
one other thought,if cam belt is fitted it could be slack.and will only make a noise for a short while.(it flaps against timing covers).
botaking123
12-23-2003, 07:39 AM
Hi,
Thanks for your advise. Like u said if its due to the cam belt. Will it harm my engine in long term. pls advise. And any other posibilites of this sound. Thanks in advance
cvcc_wagon
12-23-2003, 12:59 PM
it will harm your engine if it breaks
mechy1barry
12-23-2003, 01:24 PM
if it is the cambelt ,get it changed-pronto!
botaking123
12-24-2003, 07:09 AM
Hi all,
Today changed my engine oil from 15W 50 to 5W 30, but the sound still got.
Is there any posibilities that my car belt tensioner bearing worn out? Because my x car also happen too. same sound. After changed it, the sound gone. please advise.
*** A VERY MERRY XMAS & HAPPY NEW YEAR***
mechy1barry
12-24-2003, 12:54 PM
check cam belt ,if loose change with tensioner and idlers.
botaking123
12-26-2003, 08:54 AM
Hi mechy1barry,
Just want to ask,
cambelt, is it timing belt?
Sorry to ask stupid question, I'm very new with car technical thing.
mechy1barry
12-27-2003, 04:54 AM
yes,timing belt.
mtdxx
12-28-2003, 10:03 AM
yes, change timing belt, but how about a valve /rocker arm adjustment?
My car had awful valve noise, then someone showed me how to adjust the valves/rocker arm clearance and it has improved alot.
Could be your problem. The noise will go away after the engine heats up and the parts expand to take up the clearance between the rocker and valve, which causes noise
Jporter12
12-28-2003, 12:32 PM
Sounds like the lifters haven't been upgraded. The cylinder head is the same design as the Mitsubishi (it's made by Mitsu!) 2.0 DOHC. There is an updated psrt out there for the lifters, they have a larger oil hole in the top of them. There is a TSB out on it, and I'll see if I can find the exact info and post it.
I would check the TIMING BELT also, not specifically for the noise, but they should be replaced every 60,000 miles. I believe that engine is an interference design (valves will bend if the belt lets go) and it's a lot cheaper, and makes sense to replace the belt before it breaks, rather than have big $$$ in repairing the head.
