Chevy S-10 Water Pump Troubles
megamick50
12-21-2003, 05:59 PM
We've been working on the water pump of our Chevy S-10 Blazer for two days now, and it won't come out. We can't even get it loose. Apparently we have to take out this whole assembly thing, and the stupid water pump won't come out and we've been working on it for two days.
Any suggestions?
Step by Step intructions, please?
Anything to help.
Any suggestions?
Anything to help.
GMMerlin
12-21-2003, 06:14 PM
What year?, Engine size?
megamick50
12-21-2003, 06:16 PM
Sorry about that.
It's a 96 Chevy S-10 Blazer, and I think it's a V-6 engine.
GMMerlin
12-22-2003, 07:29 AM
All you have to do is remove the belt, the cooling fan (for which you will need the fan holder and wrench) , hoses and then remove the 4 bolts that hold the water pump to the engine block...
What part are you having problems with?
megamick50
12-22-2003, 11:20 AM
Apparently we're having trouble removing the fan to get to the hoses to get to the water pump.
Do you have any instructions on how to remove the fan?
I really appreciate your help.
P.S. I'm having trouble logging in, it'll say I'm logged on,then when the board comes back up, I won't be logged in anymore.. is there a reason for this?
GMMerlin
12-22-2003, 12:50 PM
There is a special wrench and holder to remove the fan on those models...it is a GM special tool, but it is availible from aftermarket sources
ibhuff
12-22-2003, 10:06 PM
Just a note to add to GMMerlin's post. One place I have found that is sometimes pretty good for aftermarket tools is ebay. If you arent in a rush to get this job done, try checking there.
EZE5859
12-29-2006, 02:32 AM
hey man im having basically the same problem except i need to remove the power steering pump and the water pump on a 4.3 v-6 out of a 98 s-10. To get the fan clutch off how do you use the clutch puller, and also do you need to remove the entire mounting bracket assembly to get the power steering pump off?
ZL1power69
12-29-2006, 06:17 PM
welcome to AF.
this thread is 3 years old. please refrain from posting in old threads. start a new thread in the appropriate section if need be.
