AIR DRIED BEEF DOG FOOD
b16a1 in a 90crx(dx)
dbpvmp
12-19-2003, 01:24 PM
what all do i need to put my b16 in my car.
do i need to change my clutch cable and throttle cable.
and can u tell me what else i need to change like my hubs. or anything else
Hybrid1990crx
12-19-2003, 01:41 PM
Ugh, man there is plenty of posts just like yours on here, you could have done a search first.
To start out you might as well get the full motor conversion from hmotorsonline.com. Comes with complete motor, tranny, ecu, axles, civic half shalf(works but you should get an integra half shaft), motor harness.
After you get that, you are still going to need other things.
You will need a new clutch and throttle cable, you can use the one from an integra.
Since you have a dx, you are going to have to change your fi injection from dpfi to mpfi, found in the si or hf/std crx/civic.
I know for the hf you need to get hubs and knuckles from an si, im not sure about the dx.
You going to need mounts, and also shift linkage.
Im sure im forgeting some stuff, but thats a lot of what you need.
