Low oil warning light\sound
WayneCR
12-13-2003, 06:40 PM
After getting my oil changed by a Dodge dealer my low oil warning light started coming on when I brake. I took it back to the dealer and they said that they did not cause the problem. The oil light is not the problem but every time I hit my brakes the light come on and this stupid chime just dings and dings and dings. I can pull a fuse to stop the light and sound but in also disables the dash fuel and speedometer gauges. My question is can I just disable the CHIME and HOW!!!
Thanks
firechicken1986
12-14-2003, 03:10 AM
Have you checked to see if the oil is at the right level
WayneCR
12-14-2003, 10:42 AM
Yes, dah, I'm sure it's the low oil sensor but I need a short-term fix like disabling the chime but I'm not sure how to do it.
Thanks FireChicken
firechicken1986
12-14-2003, 11:56 AM
It was not meant as a smart ass comment look who you took it to a dodge dealership
WayneCR
12-14-2003, 04:28 PM
Actually it was my wife that took it to the dealer and it's her van but I drive it from time to time with the family.
rg4541
11-14-2004, 01:27 PM
I am having the same problem, but it's not just when I hit the brakes, it will come on from time to time, I already changed the sensor on it, does anyone know if there is another sensor, or how to turn off that dang chime?
vipergg
11-16-2004, 07:19 PM
If this started right after changing the oil I would remove the filter they put on and try a different one like a Purolator and see if the problem stops . Faulty filters can sometimes cause something like this , you don't have to change the oil again its very unlikely its the oil .
Wa jang chang
03-03-2005, 03:23 PM
WARNING WARNING WARNING
My 99 grand caravan SE had 85K miles when it displayed the low oil light and constant audio warning (dang dang dang...). I stopped immediately to check the oil level. It had plenty of oil so I thought it was faulty indicator. Regardless, I was going to have a mechanic take a look right away. Then I drove about 5 miles more when it croaked and died. As it turned out it was the weak oil pump, unable to pump enough lubricant to the engine. Replacing engine cost $4700. If you want to avoid that, stop driving the car as soon as you see the warning light.
wajangchang
