B18C1 Engine Swap/Auto-Man Conversion
jmnastee00civ
12-09-2003, 10:12 PM
This is my first post...So i'm new to the forum. I have a 2000 Honda Civic EX 2 Door 1.6L. Like others, I bought this car used and got a great deal on it as well, the only thing is...It's an automatic :banghead:
I was hearing about the auto/manual conversion or just doing a whole swap. I know this can very costly, so I just would like to know what type of price range I'm looking at( Either: The conversion, Or a B18C1 Swap- Is that a good swap?) Some feedback please....
kicker1_solo
12-09-2003, 10:22 PM
The B18C1 is a very good swap, probably the most common for people with civics, great power. That's actually what I swapped into my teg. The motor usually costs around $3,000-$3,500. There's a place online, forgot where, but they'll ship it to your house for $3,300. If you're not very familiar with the whole car thing then you'll have to have a shop install it. That's gonna set you back some more bank. I would guess you're looking at close to $5,000 to have everything done to your car.
kicker1_solo
12-09-2003, 10:24 PM
oh yeah, and welcome to AF :wave:
GScivic7
12-09-2003, 11:21 PM
if you swap for a B18C1 you're going to have to convert to manual. No B18C engines came with an automatic and I'm not sure if an automatic tranny from a B18B would work. Good luck with whatever you go with.
EDIT: forget that BS up there I read your shit wrong. Go with the whole swap, you might as well if you are going to convert. If you're going to just convert, plan on paying around $1200-$2000. $5000 like Kicker said if you wanna swap and convert.
jmnastee00civ
12-10-2003, 12:14 AM
Thanks everyone for your info and recommendations. I'll probably go with the conversion since I'm putting on: AEM Short Ram Intake, DC Sports Headers, Apex'i N1 Cat Back Exhaust, Nology Hotwires....Etc. Oh yeah...Thanks for the warm welcome AF.
Donniebrasco
12-10-2003, 12:36 AM
I know in inlinefour.com they have motors with transmissions, could be worth checkin out.
GScivic7
12-10-2003, 01:19 AM
www.hmotorsonline.com
jmnastee00civ
12-10-2003, 09:06 PM
Since I'm probably going with the conversion, Is there a website or such of where I can purchase the parts that I need? If someone knows please refer me to it. Once parts are purchased I will probably get this work done here(if they do these) www.hybridynamics.com . Once again....Thanks
jmnastee00civ
12-10-2003, 10:00 PM
Okay....I browsed the Honda Performance FAQ about the conversion. I guess these are all the parts needed:
Manual Transmission, Clutch Master Cylinder, Clutch Slave Cylinder, Clutch Lines, Pedals, Shift Linkage, Manual Starter, Flywheel/Clutch, Front Console w/ Boot, Manual Transmission ECU, Transmission Mount, Front Transmission Bracket, Transmission/ Flywheel Bolts, Flywheel Cover, Shift Linkage Bolts. I guess thats it, but doesn't the gauge cluster need changed? Is there a website to buy all this, or do I have search all over the place for these parts. Just let me know, Thanks
GScivic7
12-10-2003, 11:14 PM
you don't have to change out the gauge cluster. It'd be nice though if you don't have a tach.
jmnastee00civ
12-11-2003, 05:58 AM
Okay, I did some shopping around for the parts, haven't purchased them yet. But I did find a 2000 Civic Si Transmission w/ 30xxx miles and shift linkage as well. Would this be a good transmission to put in a 2000 Honda Civic Ex? This would only be 2 of the parts in the quest to convert to a manual transmission....Input please
