DRL/Automatic Headlamps, Advice?!
usafcap603
12-09-2003, 07:27 PM
Question about DRL/Auto Headlights, can I just disconnect the light sensor in the dash under the defroster vent to turn off the automatic lights, or is it even possible to remove the relays/circuit breakers in the main fuse box. Same question about the DRLs THANKS
Flatrater
12-09-2003, 08:58 PM
Disconnecting the light sensor will not disable the DRL. It is a safety feature that I would leave alone. If I was going to do anything I would try pulling the DRL relay or fuse if equipped with them. SOmetimesall the DRL functions go thru a computer.
Pulling the fuse or relay may cause you to get a service vechile soon light to come on!
