How do you create a bonnet hood?
MR-2RaCeR
12-08-2003, 10:49 AM
Hey guyz im thinking of making a bonnet hood on my MR2 and i just wanted to know how you guyz cut the hood and puttied it.
chrismcgee
12-08-2003, 12:11 PM
please elaborate as bonnet and hoods are the same things!
are you talking about the toms air scoops or are you talking about the front hood with the drop down centre?
airforceone
12-08-2003, 05:07 PM
Bonnet=Hood
Boot=Trunk
Chris is on the right track, what exactly are you trying to do? :eek7: Remember that things are a bit different in Yurp :icon16:
Lorry=truck
water closet=bathroom
etc....
ShOrtyOC714
12-08-2003, 05:24 PM
I hope u dont mind me using ur picture Chris, this is what he is talking about. He wants to know how to make the part that angels up, he already knows how to make the air hole, but just needs to know how the scoop curves up.
http://www.scaleautostyle.com/images/ITR_hood.jpg
freakray
12-08-2003, 05:38 PM
It's an amaxing technique really.
You use sheet styrene as a frame and putty to create the curved sections.
You then use sandpaper to smooth the surface and create the final form.
Honoturtle
12-08-2003, 07:56 PM
If I remember correctly, appleseed created a little "how-to" in his FTO thread. Maybe a quick search can help you.
pre98zetec
12-08-2003, 08:14 PM
You then use sandpaper to smooth the surface and create the final form.http://www.automotiveforums.com/vbulletin/images/smilies/lol2.gifhttp://www.automotiveforums.com/vbulletin/images/smilies/lol2.gifhttp://www.automotiveforums.com/vbulletin/images/smilies/lol2.gifhttp://www.automotiveforums.com/vbulletin/images/smilies/lol2.gif
jgmodelcars
12-08-2003, 09:12 PM
^^ just what i was gonna say
try using cotton thread to cut the holes though, thats what i did for the slot for the velocity stack on my superbee, drill a whole in the center of the areas you are gonna cut, run a piece of cotton sewing thread through and go back and forth cutting it out all nice like :smile:
ShOrtyOC714
12-08-2003, 09:29 PM
Using thread would be alottt.... harder than just using a detal scribe & xacto, cuz if u use thread its alot harder to menuver than a xacto can do, it would also save the trouble, thread is alot faster but not as accurate and as easy.
willimo
12-08-2003, 10:23 PM
Actually, I would think it would be just the opposite? Cutting curves with an exacto is difficult, but with the slow sawing action that can be acheived with thread, you can easily change direction, follow complex curves, and do fine cutting. Like a jig saw as opposed to a circular saw.
jgmodelcars
12-08-2003, 11:36 PM
:disappoin:grinno:
i agree completely, plus an exacto can slip up and slide all the way across styrene then you hafta fill and fix yadda yadda, thread is much more controlled and easier to handle around corners with even better speed!
ShOrtyOC714
12-08-2003, 11:40 PM
:disappoin:grinno:
IMO i think a xacto would be easier to handle, but a thread would be easier to menuever, thats whut u was trying to say. But IMO i like using a xacto.
RallyRaider
12-08-2003, 11:49 PM
Whenever I've tried to cut with a thread it always ends up snapping after cutting a few mm. So I revert back to a #11 blade and etched saws. Don't know what I'm doing wrong, what type of thread do you guys who have been sucessful use?
jgmodelcars
12-08-2003, 11:51 PM
well its just personal preference, i like each for different reasons
i just raid my moms sewing basket for thread, you have to draw it back and forth a few times to heat up you can't just start into it, it snaps sometimes but just cut a long piece
hope this helps! :smile:
RallyRaider
12-09-2003, 12:01 AM
Perhaps that is it. Maybe I'm using too short a length, localising the heat and causing it to snap. I'll try a longer piece next time. Thanks!
willimo
12-09-2003, 12:16 AM
Hey Shorty! You used to have my wheels as your avatar, now you have my tires! WEEEE!
MR-2RaCeR
12-09-2003, 11:30 AM
I searched for the thread, but nothing came up. Can someone make a how-to?
jgmodelcars
12-09-2003, 11:59 AM
i'll make a thread cutting how to when i go home this weekend if thats what you're asking :smile:
