Turbo setup
tranquillexer
12-02-2003, 09:53 PM
Need some input on me turb setup me and the g-pa put together from his friends junkyard, aight
setup
_______
t25 dsm eclipse turbo
dsm bov
460 cc rx7 injectors(fit right in nice)
apex-i vafc
custom downpipe (me g-pa's a welder)
hf manifold with custom flange
a/f ratio guage
boost/vac gauge
and step up to 2 3/4 full pipe with arospeed exhuast
high flo fuel filter
high flo intake
wastegate set to 7 psi
so what do you guys think?
should i bolt it up and tune on a stock civic?except intake and exhaust? ned some advise?
:banghead:
setup
_______
dsm bov
apex-i vafc
a/f ratio guage
boost/vac gauge
high flo intake
:banghead:
cuba3377
12-02-2003, 11:46 PM
Great choice on the turbo. Eclipse turbos are small.......... BUT, have a quick spool up time.
If ur asking for a suggestion, i suggest u buy a bigger fuel pump, and a msd sport compact ignition box. im a big fan of ebay, and i bet u can get both for under $300. Also, make sure u check online for the instructions on the apex-i vafc. the last one i installed, the instructions were in jap!!!!
belive me when i tell u, that if its incorrectly installed, it will give u worst performance than what u would normally get ^ ^
billab2ong
12-03-2003, 02:58 AM
setup
_______
dsm bov
apex-i vafc
a/f ratio guage
boost/vac gauge
high flo intake
:banghead:
First question...intake as in CAI or intake as in intake manifold...CAI=out the door when doing a turbo install
T25...ahhhhh...go w/ a T3 .42/.48. T3's are a lil bigger
1g DSM BOV is a great choice
ive never heard of anyone using 460cc injectors...normally i hear of ppl using 450cc DSM...do you need a resistor box w/ the 460's?
Downpipe- remember you need a flange from the turbo and then another flange to the cat. many use flex pipe, its up to you whether you think you need it
HF Manifold....they are ugly but they work and they are cheap. dont be a douche and buy one on ebay...go to a junkyard. ebay=75 junkyard=35 and some manual labor
get a DSM SMIC...it helps ALOT
a/f gauges are garbage...dont waste the $40-50
Boost Gauge is a must have...
you will need oil lines which can be found on ebay from my man stealthmode
You need Vaccum lines
tap your oil pan
air filter
Mandrel Bent piping.
Also i dont like AFC...i suggest an ECU hack. but if AFC is all you can swing its better than an FMU
good luck, but def go for an intercooler of some kind...
setup
_______
dsm bov
apex-i vafc
a/f ratio guage
boost/vac gauge
high flo intake
:banghead:
tap your oil pan
air filter
tranquillexer
12-03-2003, 03:17 AM
what type of ecu hack should i be using, i think they are 450 cc, but i got them tested and they are running at 460cc... i dunno but i forgot to mention the intercooler, i have one off of a rx7 1992...
cuba3377
12-03-2003, 03:22 AM
theres so many cpu hacks out there, its not really worth it. instead, find someone that can write a custom chip for your car. ive seen the hondata system for sale, make your own.
billab2ong
12-04-2003, 11:04 PM
WTF are you talking about bro? ECU Hack=chipping your ECU. you are attaching a chip on the ecu and changing the given a/f and timing of the ECU..aka hacking it
And what kind of ECU hack depends on what year your car is. if its a 96 or above you will need to change to an OBD1 ECU i believe...OBD1=crome or uberdata....obd0=TurboEdit or Ghettodyne...they arent the easiest or most complex programs, but you need a wideband generally to tune them....its cheaper than a hondata system regardless.
