High-Flow Cats
stangv6racer
11-28-2003, 09:24 PM
Does anyone know anything about high-flow catalytic converters? Some say you lose alot of back pressure but better sound. Good idea? Better sound on a 99 v6 with flowmaster 40's with straight, true duals(no h/x pipe) and cats?
GTStang
11-28-2003, 09:33 PM
Yea your gonna lose back pressure of stock but that's the point. I honestly don't buy into the whole if you have no back pressure you lose torque.
HiFlow5 0
11-29-2003, 12:48 AM
Don't run straight pipes. There's a reason why companies make h and x pipes for mustangs, even the 6 shooters. And yes, the whole point is to make things less restrictive, and reduce some back pressure. But there is a line that shouldn't be crossed, like adding a 3" system to your car. Now that's over kill, and will obviously lose torque.
nbspindel
11-29-2003, 01:48 AM
is there a site where i can find info on differences/affects of straight pipes vs h- or x-pipes and also affects of normal cats, high flow cats, and no cats. i currently have 3" straight pipes to my flowmaster 2.5" exhaust. i learned after the install that this may not have been my best idea yet, but i have not returned to the mechanic who told me it would improve the car (and i now research before i change)!
HiFlow5 0
11-29-2003, 08:34 AM
What year is your car, what size motor, and what exactly was done for exhaust work?
nbspindel
11-29-2003, 05:10 PM
all that has been done to my 95 gt is a K&N, 3-inch pipes run straight back from the headers to the exhaust, and Flowmaster mufflers (not sure what type). the cats were taken off and left off. i get some putter when the car first starts and i give it the gas (due to lack of backpressure) but it goes away, and it doesnt seem to affect throttle response. when i replace the heads and headers later, i will replace the pipes with xpipes and high flow cats (good fix?). thanks.
351wStang
11-29-2003, 10:25 PM
high flowcats are nice. you may wanna try what i did. i've got flowtech shortys to start with. then i ran 2 3/4'' pipe back to a duel inlet/duel outlet high flow cat. ran 2 3/4 back out of it and into 1 chamber flows. and ended with 3 1/2 tips to give it a deeper tone. its load as hell! , yet sounds damn good. doesnt sound like your every day ford. just for the record this is on a 1990 f-150 with a 302/5spd. i have to say though that i have had 1 problem with my high flow cat. i blew the front screen out when i was racin a c10 so now it rattles around in there. note to self: dont turn 2nd gear up to 6 grand.
stangv6racer
11-29-2003, 11:27 PM
Alright, thanks for your posts. Personally, I don't think they would hurt. So if I can get em cheap, in your opinion, should I get them? By the way, I might get a mom & pop shop to make me a custom h pipe.
351wStang
12-01-2003, 08:41 AM
if it were me, and i wanted some decent cats for cheap then i would just buy 1. a duel inlet/duel outlet cat cost around $20 more then a single inlet/single outlet cat which is gona cost around $75 already. i payed $90 for my cat. you will get more room under the car, better ground clearance, and less back pressure.
hoodrich3740
12-12-2003, 07:05 AM
how bout no cats.? cherry bomb ur exhaust dude, straight up pwr.
HiFlow5 0
12-12-2003, 03:51 PM
Cherry bombs, ewww! There's so much better out there for Mustangs, why would you ruin it with a cherry bomb?
MustangRoadRacer
12-13-2003, 05:27 AM
yes, go full length headers if you don't have emissions laws, and skip the cats too!
deff. go with an X pipe over an H pipe, and lastly get a muffler that won't get the cops attention. the 3-5 hp you lose will be worth it when you creep by quietly.
