Abs
ogilly0753
11-28-2003, 04:44 PM
i have a 97 bonneville with abs problem. according to the mechanic the abs motor is seized delco part 25641263 w/o traction control. is their any place out there that you can buy this part cheaper or is it worth it? the mechanic quoted $619 plus install of about $300.
markwb
11-30-2003, 01:43 PM
You could try here.
http://www.gmpartsdirect.com/ (http://)
beaker1987
01-25-2004, 11:03 PM
Try a company called Eaton Tech they make motors for units similar to those. But be careful the motor shafts are offset so the pumps in the abs valve get cycled back and forth. And there are different styles of connectors that the motors use. Good Luck
