'96 Cutlass Supreme 3.1 Water pump
devo23
11-28-2003, 04:02 PM
I need instructions to replace the water pump and thermostat. It looks like I need to remove the power steering pump pulley. What tool takes this off? thanks
Genopsyde
12-02-2003, 02:34 AM
I recommend getting a Haynes repair manual from your local auto parts store, it'll show and explain it better than me or anyone else here.
The Burning Rom
12-02-2003, 10:47 AM
A PS pump pulley remover is needed to remove the PS pulley. But to replace the water pump, you probably need to remove the front cover. I'm not sure...I've never had to replace a water pump. I would also suggest getting a haynes repair manual.
As far as the T-stat, it's just the two bolts that hold the waterneck on the motor.
