Some useful info...
pRiMeRaCeR
12-13-2001, 01:53 AM
hey everyone,
i thought this info might be useful to some.
This is a link to a currency calculator.
http://www.x-rates.com/calculator.html#
Might come is handy when ordering stuff from overseas.
Also, someone mentioned something about Piaa bulbs and turning them off before shutting of ignition, etc.... blah blah blah. I found the info. here it is:
"Bulbs are guaranteed for one year from date of purchase.
Bulb failures caused by voltage surges have become more common as new vehicles have placed greater demands on factory electrical systems. The main lamp ground wire must be connected to the battery negative terminal or to a cable leading to it.
If a voltage surge occurs, the bulb will look like it was struck by lightning! The metal base & glass will be burnt or the filament will blow up!
Prevent voltage surges by always starting the engine before turning on auxiliary lamps, and turn the lamps off before turning off the ignition (the latter is the most common cause of bulb destroying voltage surges)."
thought i should quote the piaa site since i just copied it over. Hope this is useful to some. peaceout
