Dash Lighting
vtec_lude
11-21-2003, 03:31 PM
I was driving my car along the other day "95 prelude vtec". I dropped my buddy off, and when i turned around to back up, my whole dash lighting was out, along with my speedometer, tackometer, and windows. Everything else ran fine..i checked my fuses and none were blown...tightend them all and tryed it, it worked. Then i was driving it agian, and stopped to get some gas and it happened agian...they went back on about half an hour later....anyone have any idea's what this could be?? i am thinking maybe a fuse is lose..but dunno....
00tegra
11-25-2003, 01:00 AM
if you have under drive pullies it could be a result of that. other wise i'm not sure. maybe your alternator.
NeDaB20A5
01-25-2004, 03:27 PM
The under drive pulley idea sounds completely goofy to me. I hate to say it but you probably just have a loose connection. I'd check the backing of the fuse block and inspect your wiring harness for damage or melted areas. Sometimes the heater will make enough heat to melt the insulation on 2 wires together so they arch out. Best of luck.
