More GTP Problems!!!
MoshimoGTP
11-12-2003, 02:20 AM
When the car is Idle and I press the Gas Pedal quickly, the rpms downs to 400 or 500 and then ups to 1000 or more depending of the gas pedal when i press it, i think is a fuel problem, or MAF sensor, or i dont know. My car has 89k miles on it, and im very sad for that problems. I've changed a lot of sensors like the coolant sensor, and others. Can the CNSTR sensors make me this problems?. Or what do you think about?. All suggestions or comments are open.
MoshimoGTP
11-12-2003, 10:44 AM
This cold morning was more notable the problem, i need help please!.
97 WHITE GTP COUPE
97 WHITE GTP COUPE
MoshimoGTP
11-12-2003, 11:35 AM
I was reading and i think can be TPS Sensor and/or Oxygen Sensor, you who you say?. Wich first? TPS or Oxygen Sensor?.
Flatrater
11-12-2003, 05:53 PM
What is a CNSTR sensor?? I have a question for you!!!
How much money have you spent changing parts with no improvement to your car? Would it not be cheaper to take it to a good decent shop and have them find the problem instead of throwing parts on it!!
The Burning Rom
11-12-2003, 09:34 PM
SCAN YOUR CAR..get some readings. Don't just go replacing sensors until you find the problem. Either that...or take it to a decent shop like Flatrater suggested.
Also..what is the CNSTR sensor? :eek7:
MoshimoGTP
12-03-2003, 08:42 PM
Canister Sensor
BLOWN_GTP
12-04-2003, 08:55 AM
Sounds to me like an intake gasket leak.
kilroypr
12-10-2003, 09:49 PM
COuld be a intake gasket leak.
