cavalier ignition coil
jack1123
11-09-2003, 04:51 PM
Ichanged the altenator and when started back up I had no spark to cyl 1-4.changed the coil pack and the car drove about 5 miles and the same problem occured,no spark to 1-4 , anyne know what the problem might be???
wuchi
11-29-2003, 03:44 PM
I have similar problem on a 96 2.4L automatic. My car is Toyata badged but am pretty sure this is the same as a Chev Cav Z24.
I had the altenator changed also and now get anti-theft light when trying to start up. I think the anti-theft system has kicked in and has disabled the sparks from firing.
Any luck with your car?
2001CAV
12-01-2003, 10:00 AM
Did You Use Aftermarket Parts ? Aftermarket Ignition Parts
Suck I've Seen To Many Go Out In Less Than 500 Miles And Alot
Bad Out Of The Box.
sonicboomer03
12-02-2003, 04:51 PM
do you have aftermarket sparkplug wires? Mine never snap on, and sometimes fall off at the coils, resulting in no spark.
sonicboomer03
12-02-2003, 11:06 PM
