constant overheating of 1990 honda crx !!
rocprod
11-08-2003, 08:02 PM
Have 1990 honda crx that is constantly overheating and blowing lost of smoke when accelerate have just brought and replaced the radiator and that still did not help also changed the thermostat on the car but that has not stopped the car from registering that it is hot car still over heats does any one have any suggestions please. Thank You
Masta
11-08-2003, 08:28 PM
does the radiator fan come on?
Hybrid1990crx
11-08-2003, 08:40 PM
Is it throwing any codes?
SiZ
11-08-2003, 09:11 PM
Head gasket on its way out the door?
rocprod
11-08-2003, 10:01 PM
yes one of the fans do come on
rocprod
11-08-2003, 10:03 PM
where would i see those codes and is there any particular code
rocprod
11-08-2003, 10:05 PM
would you say that this could be the only thing wrong and if so do you know how much it would cost for a head gasket and how difficult would it be to change that head gasket
BullShifter
11-08-2003, 10:08 PM
If its over-heating DO NOT drive it unless you want a blown head gasket, cracked/warped head - that's not good!
check to make sure the fan comes on
pressure test radiator(check for leaks)
Compression test!
for the codes, your check engine light will be on or lift the passenger side carpet to reveal the ECU - if the read light is blinking - you have a code
Check out these links
http://www.binghamtonlife.com/manual/2gsm/images/91-11-26.jpg
http://www.binghamtonlife.com/manual/2gsm/cooling.htm
http://www.binghamtonlife.com/manual/2gsm/electrical.htm - (cooling fan, relays, senors)
Check your oil, is it miky? White smoke usually means coolant is entering the combustion chamber from a bad head gasket or damaged head. It would probably be a good time to remove the head & have it inspected & machined or replaced if needed. http://www.mmrusa.com/gudehead.htm
Cylinder head / head gasket http://www.binghamtonlife.com/manual/2gsm/cylinder_head_valve_train.htm
main - http://www.binghamtonlife.com/manual/2gsm/default.htm
Make sure to have the head inspected!
rocprod
11-08-2003, 10:53 PM
Compression test!
Thank you for your reply would you happen to have any that would show head gasket replacement
