Power Windows
zxman300
11-04-2003, 05:45 PM
My rider side front and rear windows don't work. Switch appears to be good. Is there something common to both. Find it hard to beleive that both motors went out but I quess its possible. Someone mentioned a regulator but don't know where to find it. Please help>
Jeff Williams
12-15-2003, 07:07 PM
The window regulator is the cable and plastic part, that the motor rotates on a spool, to raise and lower the window. Mine went out, but I could still hear the motor running. It went down, but would not go all the way up, unless I manually pushed it. My rear window will not move, from the console switch, but will work from the door switch. I think it is a connection problem, since the door will not lock with the romote, either. I would first check the fuses, then check the switch. Make sure you don't hear the motors, if you don't then it might be the window control unit, mounted in the door.
