******Help******
CRXVtec
11-02-2003, 04:03 PM
ok here is the deal i have a first gen b16a in my 1990 crx and my car will take a little bit to turn over and when you go to give it gas it sputters.
i just changed the plugs and wires what else can it be?? ecu is not coding
kris
11-02-2003, 04:14 PM
Did you hook the wires up in the correct order?
CRXVtec
11-02-2003, 05:44 PM
yeah i know the order and i double checked with the book
KoRnSaQ
11-02-2003, 05:55 PM
if it sputters when you hit the gass, then you might need to replace your fuel filter, which cost around 15 bucks
RedRacerCivic
11-03-2003, 12:49 AM
I second that
I second that
CRXVtec
11-04-2003, 10:05 PM
I second that
changed it still sputtering and when i go to rev it up it either stalls or almost stalls
Dumped91Hatch
11-04-2003, 10:41 PM
Maybe your cat is plugged.
CRXVtec
11-04-2003, 10:54 PM
i dont have a cat i have a test pipe
