starter problem on a 93 ranger
99silverGT
10-29-2003, 07:55 PM
my starter went bad the other day. i had to roll start my truck. i got it home and it wouldnt start. just the one click then nothing. battery is new, starter is a year old. tried to jump off the solenoid but didnt work. i tapped the starter with a hammer and now it starts everytime so far. is it fixed or is the starter still bad?
bustedratchet
10-30-2003, 06:10 AM
Sounds like you have a dead spot in the starter. It probably will work till the starter stops on the dead spot again.
EVH5150
10-30-2003, 09:51 PM
Had the same problem with my 1992 ranger. When I got the click, i crawled under the truck with a hammer that I carried in the truck. This worked for about a year until it recently siezed up. you'll know when that happens when you turn the ignition and the starter will turn over real slow and eventually just make a soft grinding noise. I got lucky and the starter siezed up in my driveway. You might want to replace it soon just to be safe. Hope that helps
RicR_wana_B
11-07-2003, 09:00 PM
i just recently had that same problem with my 93... i tried everything you did and the hammer but none of it worked so i just ended up replacing the starter... its not all that difficult to do but its a pain in the ass
Madakushka
01-03-2004, 06:31 PM
93 ranger XLT. Ive changed the starter (came with solenoid) and relay switch. Still loud click when i try to start it. Battery cables are pretty corroded but besides that im lost on what to do. plz help.
stressmaster5000
04-27-2004, 06:26 PM
I have had some problems with badly corroded battery cables in the past. Sometimes the corrosion reaches a good ways up the cable so check for it(look for loose cable covering or bubbles in the covering) and replace if needed. This is a cheap part replacement that pays off in much better electrical performance.
