I/H/E...what next? (99gsr)
pbizzlegsr
10-29-2003, 04:22 AM
wasup everyone..so far i have a tsudo fireball catback, aem intake, and dc 4-2-1 header. what upgrade should i do next to get an increase in power? i was looking into maybe an act flywheel which i hear makes your acceleration faster...cams, but i hear installation cost a lot. so..any suggestions?im not lookin into any expensive in the thousands like turbo or anything in the future..just an all motor setup..
Spectre927
10-29-2003, 10:45 AM
Get some cams and cam gears. Ive also heard that too, they say for each gear, its like taking out another 100 lbs in your car, something to do with the stock one being better for momentum, rather than acceleration.
pbizzlegsr
10-29-2003, 05:01 PM
anyone else?
KrNxRaCer00
10-29-2003, 06:57 PM
i agree w/ spect.
the cam/cam gears are pretty essential to building a motor up.
if u don't want to go that route, wut are u going for? all motor or FI?
sorta need to know that before we can give any bigger answers.
pbizzlegsr
10-29-2003, 08:10 PM
all motor..
pbizzlegsr
10-29-2003, 08:24 PM
if i were do cams and cam gear..is there any tuning or custom engine work needed or just bring it to the shop and once installed its done..over time is it known to cause any engine probz..and last what kind of cams for gsr
Spectre927
10-29-2003, 11:33 PM
You should do some research. I mean, some actual, not just post a question research. If you didnt know that cams are extremly important in an all motor build up, you should read some more, unless I misunderstood you. No offense by the way. And all motor is really expensive, if youd rather spend less, go FI.
Spectre927
10-29-2003, 11:46 PM
Cams and Cam gears, once installed, should be DYNO tuned to extract the most possible HP. If you change other things, you'll probably need to redo there adjusting to once again get peak performance Cams can vary tremendously. It depends on your setup, what you want, what it can handle, and where you want power.
pbizzlegsr
10-31-2003, 03:13 AM
i heard that with ctr cams i would need to mate it with an Integra R exhaust cam to compensate..i cant just have the shop install the cams alone without any custom work? any other ideas on a next mod?
Miataracer
10-31-2003, 03:22 AM
if it was me I wouldn't dive right in to swap the flywheel until you were ready for a clutch as well... then you can dig in there and really make it worth your time to throw in a new better clutch, light weight flywheel, and of course new pilot and throw out bearings...
Spectre927
10-31-2003, 01:20 PM
Yeah, unless you jus do it anyways even if you dont need a new clutch. I think you'd need some type r valve springs, I heard something about moving the intake springs to the rear, and putting dual springs on the front? Type r would be good enough, or if you really want power, just get some toda stage 2s(better quality I've heard than skunk2s) or something like that.
purespeed187
11-01-2003, 09:51 PM
a flywheel is a good way to go and while your at it install an upgraded clutch if not that go cam gears and pulleys or if you want cams go with stage =ones even though stage two are well worth the price of putting them in
97gsr
11-02-2003, 08:13 AM
hmm.. I/H/E... what's next?
well... thats up to you...
do you want to spend $8000 making this thing fast(all motor)?
or do you want to spend $4000(FI-boost)?
KrNxRaCer00
11-02-2003, 11:44 PM
depends, he could easily spend $8k on a FI motor. he's going to have to reinforce/stregthen his motor a lot for it to be able to take any type of real boost.
