p.o.s.
bigdog3
10-24-2003, 12:48 PM
need help with sprak and electronice control. replaced coilpack and module and crank sensore, but still no spark
BOOZER
10-25-2003, 07:29 PM
You also need help with your posting. Might work better if you put in some info.
W-44Olds
10-26-2003, 12:56 PM
What year is the car? Did you know you can go to autozone and use their rent a tool program.And you can rent you a scanner for the ecu.It may be your Ecu.One side controls fuel and the other spark.I had similar problems with a 89 Z-24 and it was the ECU.It beats the heck out of guessing by using a scanner.It might be worth trying out.Hope this helps a little I know how angry it can make you just blowing money trying to find it. :banghead:
