Integra Type R ecu on a B16a.
ZORT
10-22-2003, 03:26 PM
Has any one every used a integra type R ecu on a B16a if so what happened. I am contemplating running a Type R ecu on a boosted b16a. Any comments recommendations
Moppie
10-22-2003, 03:39 PM
Yip it should work, the only problems you have is if you have OBD II ECU and an OBD I engine, you will have to fit a 2nd O2 sensor.
Generaly any B series VTEC ECU will run any B series VTEC engine, but like all honda ECU's from that period it will still only manage up to 6psi of boost before either a piggy back is needed, or a complete Hondata ECU.
Ricochet
10-23-2003, 12:38 PM
Isn't that what a missing link fixes?
crabby760
10-27-2003, 09:36 AM
the obd2 ecu wont even plug into to the obd1 wiring from the ecu on the b16a if its obd1.... i have a 95 obd1 b16a and i tried to use a 99 b16a2 si ecu obd2 and the plugs are way off...
ZORT
10-27-2003, 01:41 PM
So let us say the plugs lineup perfectly. What increase can i expect if any.
zort
zort
crabby760
10-27-2003, 01:49 PM
if they line up u most likely will get more gas from the type r ecu and little things like timing and stuff might change but im not sure...
