Problem noise
Keddy_StangGT4.6
10-18-2003, 11:35 PM
hey all i just signed up bc i got a 96 mustang gt for my first car yea guess i am spoiled but theres reasons so its got 60 thousand miles on it but at low rpms it makes a noise a light ping/viberting noise i was told it was the valves and its normal at low rpms and i have been told that my engine is misfireing etc also my 2ed gear grinds even when i put the clutch to the floor when i shift hard some times gentle out mybe my gears out of synch? ty for the help everyone and hope to chat with u all.
Ken
Ken
GTStang
10-19-2003, 01:47 AM
#1 That ping noise is not normal and something is wrong. #2 Sounds like your tranny has a bad synchro.
Keddy_StangGT4.6
10-19-2003, 08:43 AM
thanks yea i read that a guy had a corba and it was doing the same thing so what should i get done can i replace the sycro or does that requrie a new tranny?
Something wrong with my engine, ight any clues or thought what it can be so when i take it to the mechanic he doesnt add a few things sense i am a kid so advence to any mechanics. its happend to me before. my car also burns oil told mybe head and head gasket bad? i really appracite it ty
Ken
Ken
stang_racer20
10-19-2003, 11:34 AM
if its just a slight ticking sound, its probably worn bearings, most likely main bearings. i doubt its your valves
stang_racer20
10-19-2003, 11:35 AM
then again could be lifters! try to listen where the sound is coming from
Pyromaniac79
10-19-2003, 02:52 PM
I don't know much about trannys, but if your engine is a 4.6L it won't be your lifters (doesn't have any). Has anyone ever changed the timing on your car?
HiFlow5 0
10-19-2003, 03:13 PM
The pinging could be something as simple as a exhaust leak. But since you said your car burns oil, it could also be a number of other things. Bad seals, bad rings, timing etc.
GTStang
10-19-2003, 11:33 PM
Bad synchro in tranny can only be fixed by tearing the whole thing apart so at that rate you might as well have it rebuilt. The ping could be a lot of things if I heard it in person I could give you a better idea, sorry. Check engine light you need to run codes to know what code is trippin the light.
