wheel size??
bgchrs2004
10-17-2003, 03:44 PM
ok i want new wheels and tires on my car. i want bigger rims and lower profile tires without changing the overall size of the wheel so it will not mess up my speedometer.
my tires:
P215/60R16
if i put on 17's i will need wut??? is this right or not?
P215/30R17???? im just not sure about the aspect ratio...
30% of 215 is 64.5 but how many millimeters are in an inch???
my tires:
P215/60R16
Cy@tirerack
10-17-2003, 04:43 PM
What's the year, make and model of the car?
bgchrs2004
10-18-2003, 09:41 AM
94 cutlass supreme sl 2 door but why would that matter? not tryin to be smart or anything, just wondering
Cy@tirerack
10-18-2003, 10:24 AM
I need the vehicle information to see what we've test fit for your car. The 17" tire choices that would be compatible would be:
225/50-17 25.9" diameter
225/55-17 26.7" diameter
Your 215/60-16's are 26.2" diameter. 1" = 25.4mm.
[email protected]
Performance Specialist
Moderator www.automotiveforums.com. To place an order please call 888 541 1777 Ext. 622 or for internet orders through www.tirerack.com please mention my name in the previous contact field directly above the Place Order button on the Order Summary page for quick, efficient & professional service.
[email protected]
bgchrs2004
10-18-2003, 09:34 PM
just wondering.....how did u come up with 26.2????
ok i did 215mm x .6 = 129mm so 60% if 215mm is 129mm right???
ok so 16inches + 129mm = total wheel diameter
so 16inches x 25.4 = 406.4mm
so 406.4mm + 129mm = 535.4
so the total wheel diameter is 535.4mm
535.4 / 25.4 = 21.07"
i got 21.07" as the total wheel diameter and u got 26.2, how??
CapriRacer
10-19-2003, 06:45 AM
Re diameter -
you need to add the section height twice so 129mm + 129mm + 16" = 26.2"
Hope this helps.
Hope this helps.
bgchrs2004
10-19-2003, 09:26 PM
o yea haha how could i forget that...DUH!
MOS95B
10-27-2003, 03:56 AM
Give this a shot. It's a tire size calculator. Will tell you, and show you what different sizes will work. Include speedometer difference
