Old 10-17-2003, 11:52 AM
CRXsk8er CRXsk8er is offline
Send a message via AIM to CRXsk8er
vtec question and locating of knock sensor?
ok i wired up the vtec and everything and when i hit about 5500 rpms you can hear the vtec kick in but it makes a really loud noise like sumthing it wrong so i have like went farther then the noise cause i dont want to fuck anything up.....do any of you guys kno what it could be and i also needed to kno where the knock sensor is located??.....
Thanks Chris
Old 10-17-2003, 12:21 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: vtec question and locating of knock sensor?
I dont think the knock sensor has anything to do with that noise you just described. Anyways its located behind the block. You'll see it, its green.
Old 10-17-2003, 12:58 PM
Re: Re: vtec question and locating of knock sensor?
k thanks man i found it its already hooked up s i dont have to mess with it i dont think but i had a friend come over and he drove it and he said that the nosie was the vtec kicking in but its really fucking loud its crazy i love it and its pulls you back in you seat......and i was checking for codes does anyone kno what these codes are 14, 21, 22, and 23
thanks guys....Chris
Old 10-20-2003, 04:02 AM
mellowboy's Avatar
Re: Re: Re: vtec question and locating of knock sensor?
Ok i know this sounds weird but if its throwin code 21 and especially code 22 you're v-tec wouldn't work. I have a code 22 right now but tahtys because my ecu pin is loose. Easily fixed. Sometimes it could be bad v-tec solenoid. Not quite sure about 21 and 23 though.
Old 10-20-2003, 12:37 PM
kris's Avatar
kris kris is offline
Off playing with fire.
I dont know what those codes are off hand, but I sure as hell wouldnt be driving my car with 5 or 6 different codes being thrown.
Old 11-18-2003, 09:46 PM
turbobrat turbobrat is offline
Hey if you haven't yet got what the meaning for them code yet. Well here it is. Man you sure have lots of sensor going wrong there. Its probably because if you bought a motor from somewhere. Most of your sensor probably got messed up or something, because all that code you mention are all sensor. Well anyways here are the code meaning. Good luck.
Code # 14---- IAC VALVE (IDLE AIR CONTROL) IT EIGTHER HAVE A DEFECTIVE CIRCUIT OR ITS UNPLUGGED, JUST CHECK ALL YOUR SENSOR MAKE SURE THEY'RE PLUGGED, IF THEY'RE ALL PLUGGED, THAN THAT MEANS THAT YOU WILL NEED A NEW ONES. DEFECTIVE SENSOR.
Code # 21---- VTEC SOLENOID VALVE CHECK, AGAIN CHECK TO SEE IF ITS PLUGGED, IF ITS PLUGGED THAN ITS DEFECTIVE SOLENOID VALVE.
Code # 22---- VTEC OIL PRESSURE SWITCH DEFECTIVE CIRCUIT OR UNPLUGGED. DEFECTIVE OIL PRESSURE SWITCH.
Code # 23---- KS (KNOCK SENSOR) DEFECTIVE CIRCUIT OR UNPLUGGED. DEFECTIVE SENSOR. WELL GOOD LUCK.
ANYONE ELSE NEED THERE CODE LET ME KNOW, I KNOW ALL OF THEM. JUST DROP ME AN EMAIL. AT [email protected] THE NAME IS TINO.
CODE 43, and 2 knock sensors? InDeepShitNow Blazer 1 05-11-2010 08:20 AM
1G and 2G knock sensor question??? Drive-Maniac Engine, Transmission and Drivetrain 8 03-04-2009 07:59 AM
diagnostic plug location/knock sensor Retard324 Prelude 2 10-01-2005 03:07 PM
ls vtec knock sensor aznbmxxxer JDM Motor & Parts info/chat 1 04-25-2005 02:43 PM
does the SOHC VTEC (D16Z6) have a knock sensor? Barwick '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 04-11-2002 04:54 PM
