front axle - not disengaging
DavidK
10-13-2003, 08:29 PM
The front axel has a vacuum assest lever that slides a sleve over the threaded axle. For some reason my front axle will not disengage. I have tested the vacuum motor and it works fine. It appears that the vacuum switches from one side to the other on the vacuum motor. For me to get the front axel to disengage a moved the two line vacuum hose to the other port. Does anybody know why this is happening? Thanks
spooleffect
10-14-2003, 01:07 AM
Just buy a manual engagement coversion and get rid of that unreliable vacuum system.
DavidK
10-16-2003, 08:23 PM
Thanks, did not know one existed, can you give me more info so I can purchase one.
cherokee842002
10-17-2003, 01:40 AM
its called 4x4 posi lock just about anywhere that sells jeep parts will have one
XJnick
10-17-2003, 09:56 PM
Instead of buying one, you can make your own for real cheap!
Here is a great write-up on how it's done: http://home.earthlink.net/~stevenschreiber/cabledis.htm
-Nick
DavidK
10-18-2003, 08:41 AM
-Nick
Great. thanks.. This jeeps is my sons(13) and I want him to learn to be resoucefull.
