Firewall in a P11?
Koojo
12-06-2001, 09:23 PM
Im trying to run some wires through the firewall, and I am looking for a hole somewhere in it (preferably on the drivers side, but if there is one on either side, let me know). So if anyone knows...please help!!!!! lol thanks
frogg
12-06-2001, 09:35 PM
Look to the left of the brake pedal and there should be a little "cutout" for a hole. You will have to take out the cutout and drill a hole from there.
AznVirus
12-06-2001, 10:48 PM
ya easiest way is to find the cutout and use a coat hanger, it should end up in the engine bay somehow. or you could go the easy way and drill, but make sure 100% that theres nothing on the other side.
frogg
12-07-2001, 02:12 AM
On my car, there was the cutout in the cloth, but no actual hole in the firewall. I had to drill, but comes out right at the top of the engine bay..
G-Forces
12-07-2001, 08:21 AM
That's probably where the clutch should go. :D
Koojo
12-07-2001, 09:53 PM
im just running some wires into the car so i can put a switch for these lights that im putting in. I need one small hole in the firewall, and I dont want to drill anything. someone said its to the left of the brake pedal? I have an auto). Also, i have to remove the carpet where the pedals are to find the hole right?
frogg
12-08-2001, 12:40 AM
Yes, to the left of the brake pedal. I also have an auto.
Ok, look for the cloth that is a dark brown color and is "insulated" kinda.
You will find a little "cutout" in the cloth. You will have to take off the cutout and drill a hole. Believe me, there is no other hole that is already there. I spent 2 weeks looking.
Koojo
12-08-2001, 05:56 PM
so after drilling the hole and running wires through it, do i need to stick anything in the hole so that water or other stuff doesnt get inside the car? i know the hole is pretty small but still you know
frogg
12-08-2001, 06:11 PM
I believe you can put silicone on it to seal it up, though what I did was make a hole just big enough and used rubber grommets.
