Rough Idle HELP
cats2004
10-12-2003, 05:52 PM
Car Idles very rough . Used to go away and smooth out if you turned on the headlights or put any electrical load on the engine. Now the you need a BIG electrical load on the engine. Seems the radiator fan is the only thing now that smooths out the rough idle. I already changed wires and dist. cap....any ideas would be VERY helpful...thanks.....
blueturtle
10-16-2003, 09:41 PM
did u check the vaccum lines or adjust the idle screw
cats2004
10-16-2003, 09:48 PM
No, didnt touch idle screw, I dont wanna increase it because its idleing where it should. I looked over the vaccum lines I am aware of. There is no noticeable hissing or loose hoses anywhere I could find. IM GUESSING maybe a bad valve lash setting?
