To remove a Humbrol.. CSC or DOT5 ??
AngelSaxo
10-08-2003, 07:38 AM
hi!
i need remove a humbrol enamel of the body of 206...
The primer coat is a tamiya acrilic; the next coats are a humbrol enamel, 2 or 3 coats....
well, i live in spain and i dont know the CSC, and I don't know if I will be able to find it in the stores...
works well the DOT5? The range of DOT yes that I can buy it easily, but i don't know if it will remove the enamel completely and if it damages the plastic of my 206...
Guys, i need your help urgently!!!
if nonencounter CSC, what DOT recommend to me? use form?
Very very thanks people
V1nce
10-08-2003, 09:15 AM
ive used mr muscle oven cleaner foam before to great effect with humbrol enamel, dont know weather youll be able to pick that up in your part of the world, but imagine all foam oven cleaners are the same.
just washed car panel paint off my civic coupe with 4 dot brake fulid. was also a bit unsure about damaging the plastic at the start, but if you think about it that stuff comes in plastic bottles!!! bathed it for 24hrs then rubbed the paint off with an old tooth bush, stripped back to plastic !
